Motor mount and other winter projects
Posted: Mon Dec 12, 2016 10:23 am
Hello all,
I'm putting my mind to possible winter projects and am hoping for some expert advice from the forum.
Motor Mount
I have a small Mercury 2.5 HP motor on the motor well. I'd like to put it on a mount to move it a little back and down closer to the water to prevent the motor from fouling in the main traveler when it's in it's upright position. Has anyone here added a motor mount to their DS? I'm looking for something that is static keeps the motor as close into the boat as possible. Something like this, but with shorter extension arms... https://www.amazon.ca/Panther-55-0028-4 ... otor+mount
Floor Boards
Last summer I sanded and re-varnished all my floorboards and the strapping underneath. The strapping wore a bit due to friction of the season and I notice the wood taking on water. I'm thinking of sanding and epoxying just those parts of the floor boards. Has anyone done this? Would it effectively seal the wood? Can I do them while the floor boards are assembled, or should I disassemble them?
Running Lights
I'm trying to work out a way to run wiring for running lights for late evening navigation and overnight mooring. My I've been trying to map out a way of running the wires so that I have a tri-light and mooring light on the mast-head, but I'm worried about fishing the wires through the mast while the original foam (still in good shape) is still intact. Any thoughts on this? Am I just making life hard for myself by trying to put everything at the top of the mast to keep everything clean?
Thanks in advance for any and all advice.
Motor Mount
Floor Boards
Running Lights
