I'm upgrading my 1978 DS II, and am going to be using a ratchet block on the Jib sheet. I ordered and got a Harken 40mm carbo ratchet block. It doesn't seem to hold very well, It doesn't seem to make much diference whether the ratchet is turned on or off. The jib sheet is 3/8", the maximum size listed for the block, but it may be too large to fit into the ratchet on such a small diameter sheave. The only other ratchet block I've ever used is the one left over from my once owned Hobie 16, which block stack, by the way, in a de-tuned version, is going to replace the stock DS system . I tried that ratchet block from the Hobie on the DS II sheet and it held quite well (it's way too large and heavy for this purpose!). The Harken block has five facets on the sheave, while the block from the Hobie has multiple grooves. Would a 55mm block work better? Could another brand, Ronstan for example,(it's claimed to hold better) be a better choice? The 4mm block seems quite small and would possibly be more an appropriate for a smaller line. My wife, The Jib crew (Her first time in a sailboat was last Sunday), Would really appreciate your help. I'm going to put a cam cleat on the center board cover, but a functional ratchet block would also be very useful.
Thanks for your help in this matter, John
