Anyone found a swim ladder/rescue ladder which works well with the DS II?
Rakozy
GreenLake wrote:Not sure from your description which model you ended up selecting. Also, does the ladder extend into the water while you are under way? I see from a different post that you mostly motor while waiting for your mast. Dragging a ladder through the water is no fun when sailing.
