Cuddy door plans for DSIII
Postby jefflw » Wed Feb 25, 2009 11:52 am
Im wondering if anyone has plans/dimensions for building a cuddy door for the DSIII. My model is from 1985 and has the larger cuddy opening. D&R Marine lists one for $149 made from teak (link below). If all else fails I may go for that, but I want to install one that can be locked.
Tx
http://www.drmarine.com/proddetail.asp?prod=DS240
"Swallow" DSIII
jefflw
I built a one piece lockable door for my DS II
Postby Roger » Thu Feb 26, 2009 1:44 am
e-mail me at roger02 att mts.net and I will send you some pics. Essentially, I built two side rails with a slot to accept the hatch. As well, I added a sloped lower sill that the door rests on, and the top of the door is flush with the cuddy roof, and has a lip that extends slightly forward to make it rain proof. I also added a louvered vent.
To make the pattern, I had a buddy hold a large sheet of cardboard from a furniture box over the outside of the cuddy opening, while I was inside and traced the outline of the hole. From this I worked up the pattern.
Part of the detail of the upper right portion of the door can be seen in this pic which is in the photo gallery.
571
Return to Day Sailer III Only
