jeadstx wrote:Greenlake, you mention on the DS1 that you can work from both sides of the hull to add the stringers because the DS1 hull is exposed. Could the DS2 be repaired in the same manner by putting in maybe two 8" inspection ports on each side of the centerboard trunk in the DS2 cockpit sole. That would allow access to the bilge area without compromising the hull with any cutting. With ports in the cockpit sole they could be sealed when the work is done and provide a way to check on the work.
I know I've put two 8" inspection ports inside my cuddy cabin to have better access to the centerboard bolt. A secondary reason for the cuddy cabin ports was for additional storage low in the boat on the Tx200.
Swashbuckley wrote:Thanks for the comments guys. Yes I have some thinking to do. I originally acquired this boat to sail the TX200. So at this point I do not see racing it. I expect it to be sailed hard and endure some damage. OK, so to restore it I would have to totally restore the hull shape. As a racer a DSII is not useable. As a former racer I want her to perform well.
Greenlake I like the info on battens. Thinking outside the box. What would be the effect of putting the batten on the outside? Performance wise? It would make it more durable for coastal sailing. I think the process you outlined would work great to restore the shape of the hull. The battens would stiffen and be sacrificial on beaching.
