I have purchased a 1968 DS1 with a cast bronze handle on the centerboard trunk. In the handle mechanism there is a single tooth on the edge of the circular pivot that seems to hold the centerboard up. Should the centerboard be completely retracted into the bottom of the hull when in the locked up position(with the tooth)? In the locked up position, my centerboard still hangs below the bottom of the boat about 6" - 8". If this is a problem how do I go about fixing it.
Scott Elstad (elstad-at-mindspring.com)
