The KALEIGH B and her transformation
Posted: Sun Apr 21, 2013 11:02 pm
Last October I bought a 1983 Daysailer 2 with a trailer from a woman who had inherited it from her Dad. It was named the LORRI DEB. I was dealing with Lorri, who never had time to use her. The boat had sat for 8 years. The first challenge was just getting it home. The LORRI DEB was 120 miles away. As anyone with a boat knows, the trailer is almost as important as the boat. I arrived with $500 cash, 2 new wheels and tires, bearings and grease, tools, jack, jack stands and numerous ratcheting tie downs, bungees and miscellaneous ropes. The bearing were the the wrong size so we repacked as best we could, replaced the wheels, lubed the s#!t out of the hitch, tied everything down to both the trailer and my truck, attached a plate from my Hobie 16 trailer and away we went... Light-less. It was a long, tense ride from Pittsfield MA to Chelmsford MA using GPS and for the most part taking the road less traveled.
Home, safe and sound.
It sat all winter as I did my research, made my phone calls and visited numerous marine supply houses and Internet web sites. My first true fixes were done to the trailer, literally starting from the bottom up. New hubs with grease fitting drilled into the back,with bearings. They accompanied a new set of wheels as well. I replaced all 5 keel rollers, including new shafts. Two new 4 foot pressure treated bunk boards lined with plastic slides were also installed. I got rid of the rusty old winch that was using old nylon line and replaced it with an upgraded, strap and hook type. Also added was a retractable wheel for moving it around the yard. The lights were addressed, the ground had come undone. Lastly anything that wasn't galvanized and rusted was wire brushed, wiped down and painted. It is with complete faith that I will put KALEIGH B in the water anywhere I want, unhampered by a shoddy trailer.
The Boat...
I have seen all the posts that make reference to Rudy and Debby Nickerson at D & R Marine in Assonet, MA. He has been called the guru, the Jedi and Mr. Oday on this site... He is all of that and more. He and I along with my father have spent hours working together on my boat. I don't just mean showing up at his shop and picking up some parts or making me some lines and stays. We were in his yard, tools in hand, getting dirty. His knowledge of this boat and its history is unmatched, at least in my circles. He, his wife and daughter run one hell of a great business, all through word of mouth. I would count myself lucky to have had the access to Rudy like I did. Not everyone will have this opportunity. Timing is everything. If I did nothing else with my boat I met an absolute Oday genius in one Rudy Nickerson. Not to mention meeting his family that helps make his shop what it is.
We replaced all my running rigging with the upgraded wires and full sized turnbuckles. What a difference compared to the originals. The forestry was replaced as well with the quick connect/disconnect fitting. If you are trailering your boat and need to make an upgrade in the rigging, start with the quick connect fitting. It really isn't that much more money but works super slick. The stemhead needed to be replaced as I was installing a Harken roller furling system, Rudy was key here. There was much more to just slapping the furling kit on. We had to move the jib halyard block and forestay tang. I added the upgraded spreaders and boots. Again, there is no reason not to go for the upgrade here. It is minimal money to never have to address them again, like $5 or something. The boom vang was missing so I picked up the kit.
A new Garhauer Main sheet block and base replaced our old rust one. Garhauer single swivel blocks were purchased and installed along the jib car track. This lead to Ronstat 360 degree bulls eye cams that are mounted on the trunk for jib sheet controls. The Bulls eye cams were about the only part of my boat I did not buy from Rudy.
I replaced every line on this boat, right down to the tiller lockdown line and centerboard controls. Each one had its end sealed and whipped with nylon whipping string.
I purchased new cuddy doors and the plastic edge protection for the fiberglass cuddy edge. These may be MY favorite part of the new KALEIGH B. they look amazing. Rudy actually makes these in his shop, each set is custom made using marine grade teak. His advice, and I will take it, is to seal them with Cetol. My tiller was also replaced, including the hardware and will be sealed as well with Cetol.
New striping and lettering have been purchased from D & R to give it that original look. They are going to be installed by my buddy at MILL CITY AUTO BODY in Westford MA this week. With Rudy's recommendation I had some fiberglas repair work done by J & R Boat Repair in Lakeville MA. He installed an 8" inspection port over a crack that I had in the floor by the stern, repaired the stringers in the cuddy cabins roof. These were cracked in numerous places from what seems like too much weight on the deck. He installed a new bilge drain. Inspected my centerboard and cable. He removed all he original striping that was crazed and faded. The hull was buffed and polished, and bottomed coated with Interlux Micron 66.
The last thing I have left is the mounting board for my outboard. We picked up a 1997 Mercury Mariner 5 hp long shaft. It is 2 stroke with a built in fuel tank. The boards are going to be made from the same material they make cutting boards out of. It is worry and maintenance free.
Well that's it... I think I have covered everything. I will get some pictures out after the stripes are put on, hopefully this week. It will be dry sailed this weekend. Plenty of pictures then as well.
The Boat...
