replacing wood type
replacing wood type
Postby Fly4rfun » Tue Oct 20, 2020 8:55 pm
My DS has some wood some missing and issues with some others. I have some White Oak, Oregon coast wood milled by me, I also have some poplar, both are rough cut. the oak 1/4grain cut, (vertical grain) its 25 years old. the question which would be best to use to replace what i need too. i would re-saw and plane to appropriate thickness. trying to save $ and not buying the teak or mahogany that is bad.
thanks
"Sail Aweigh" 1966 DS1 #2675
Fly4rfun
Re: reolacing wood type
Postby GreenLake » Tue Oct 20, 2020 10:47 pm
Poplar is rather prone to rot. White oak would be better, but probably not as good a the top level marine wood species. Still best to seal anything in epoxy.
Postby Fly4rfun » Wed Oct 21, 2020 7:30 pm
I have much more Oak than poplar, had boards 22 in wide vertical grain.
Fly4rfun
Postby Fly4rfun » Wed Oct 21, 2020 7:35 pm
I'm sitting here looking at a coffee table I made my Mother while a Jr in High School, it is a little worse for wear, when I'm gone it probably will be tossed. the idea came to use the wood for what i need. Transom trim and cockpit seats, possibly the wood on the cuddy lip from side to side
Fly4rfun
Postby Fly4rfun » Tue Oct 27, 2020 9:46 pm
Also i forgot I have about 300 bf of black walnut rough cut i could use
Fly4rfun
Postby GreenLake » Tue Oct 27, 2020 11:45 pm
Before deciding on any wood species, be sure to look up whether it's rot resistant for outdoor/marine use.
