Wood Beautification
Posted: Sat Jan 16, 2021 7:13 pm
I've been reading a number of threads on the DS wood, but I can't quite get a concise feel for the restoration process. I have a number of questions...
1. I took out all the screws, but the wood on mine seems pretty well adhered to the hull. Is it worth cutting them off, or should I refinish in place?
2. Today I cleaned the wood with a wood cleaning product and a scotch bright pad. I seemed to get a bunch of dirt and scum out. What should the next step be? I could sand down, but with what grit level?
3. Oil vs Varnish? It seems like the wood on mine was oiled. It certainly does not have any sort of gloss. I've read though that mahogany does not take oil as well as other woods, so should I go with a varnish instead?
My basic understanding right now is that I would leave the wood in place. Sand with 180 paper, clean again, sand with 220 paper, clean, and then start applying coats of whatever product I choose to use.
Conversely, if I choose to oil the wood, my thought is that I clean again, sand with 220 paper, clean, then go to applying coats of oil.
I'm no expert here though so, I thought I'd check with y'all before I do much more.
