Bilge pump
Found this interesting video on a cheap way to set up a solar powered bilge pump, with dual use of the battery also for nav lights.
https://youtu.be/mP_dQClOic4?feature=shared
The bilge pump setup looks clever, but I'm not sure what to think of the suggestion to use LED strip lighting to mimic navigation lights. Proper nav lights have a restriction on the sector that they are illuminating, so that when you see them at night you know what (possible) direction the other boat may be pointing with respect to your boat.
For example, if you can see (only) the stern light, you are the overtaking boat and need to keep clear (sailboat or not).
However, I think you could use this system equally well with LED powered nav lights that are properly constructed (and configured for 12V).
