Re: Two block or not to block
Posted: Wed Jan 16, 2013 3:02 pm
I've really got to stop writing this stuff from memory. It's a rearward yank to uncleat, and a forward yank to cleat. Once you've uncleated, the sheet runs out fairly easily. (That's the port side jib fairlead in the photo - the upper end of the line runs up onto the foredeck and the lower end is the bitter end.)
This completely blows my plan to turn the unit around and install a ratchet cheek block to change the direction of the sheet 180 degrees. At this point, I may just leave well enough alone and see how it sails as is.
