Motor Choice Help
Wed Feb 24, 2021 7:18 pm
by Beach4824
Im looking into buying a 2 hp with a 20in shaft. Question I have, would a 20in shaft be too long ? Thanks.
Re: Motor Choice Help
Wed Feb 24, 2021 8:30 pm
I don't think so. I'm using an electric outboard w/ > 24" and used a trolling motor before w/ 36" shaft length. Both mounted directly on the transom (on a DS1). The prop diameter for the electric outboard is larger than typical for an outboard, so 20" should be fine, particularly if you are mounting on some bracket that might allow you some additional adjustment.
Wed Feb 24, 2021 10:07 pm
by jalmeida51
I use a 2.5 H.P. Yamaha 20 inch long shaft. Plenty of power I usually never go more than 1/2 throttle. It is attached to the built in motor well. If you use a short shaft you might have a problem with cavitation motoring in choppy waters. Most motors that are under 2.5 HP don't have reverse, to reverse you have to turn the motor 180 degrees. It takes a little time to get used to if you have to motor in tight areas. I always carry an extra gallon of gas just in case I run out of gas.
Thu Feb 25, 2021 7:53 am
by Beach4824
Thanks, I have a Daysailer II with a motor mount bracket about 6in off the transom and on the port side.
Thu Feb 25, 2021 6:05 pm
Vertical or horizontal for the 6" ?
Fri Feb 26, 2021 9:55 am
by Beach4824
Horizontal
Fri Feb 26, 2021 2:49 pm
If the bracket is the same height as the transom, it would be the same height as the "motor well" in a DS1 that Jim mentioned. So you should be fine. I guess
