Postby Themanfromuncle » Sun Nov 17, 2019 9:49 am
1968 DS1 Sail # 3319 Hull #18167 FIREBALL XL5 Maryville, TN Tellico Lake
Don Thomas Themanfromuncle
Themanfromuncle
Postby RobH912 » Thu Dec 12, 2019 8:17 pm
Just found this thread...
New boat to me this fall.
1966 O'Day Daysailer 1
Hull number: 14028
Sail Number: 2444
Rob
DS1 #2444
Cape Cod
Eastham, MA
RobH912
Postby MediumMike » Wed Feb 05, 2020 7:37 pm
Greetings all,
We have a 1976 Daysailer 2
Hull # 8094
Sail # ????
Beaufort NC
Medium Mike
MediumMike
Postby GreenLake » Wed Feb 05, 2020 11:35 pm
For any boat past ~ '71 the two numbers are the same.
Postby sailingcastle » Tue May 26, 2020 11:26 pm
Well, I have been smitten and purchased a second O'Day Daysailer. This one too will need some TLC but will shine again someday. Hull No 9243 Class No 1627. Looking forward to sailing our two O'Days side by side. This is Princess Smurf, she will sail in Central Minnesota.
IMG_8712 (6).jpeg (94.58 KiB) Viewed 979926 times
IMG_8719 (6).jpeg (107.74 KiB) Viewed 979926 times
IMG_8710 (6).jpeg (137.53 KiB) Viewed 979926 times
sailingcastle
Postby marcthomas » Mon Jun 08, 2020 9:52 pm
dssec wrote:13158 - Hot Flash, El Dorado Hills, CA (1989 - mclaughlin)
13162 - Vagabundo, Fresno, CA (1989 - mclaughlin)
13150 - True Blue, Fresno, CA (1989 - mclaughlin)
316 - Vieja, Fresno, CA (1959, O'Day)
13310 Evelyn B Muncie,IN (1989-mclaughlin)
marcthomas
Postby jboright » Mon Sep 28, 2020 1:17 pm
2055 "Bobbie" Burlington VT
This is an update to the list apparently... as 2055 already has an entry. Judging by the neighboring entries I'm guessing she's a 1960 (?) Other insights welcome.
Jon
ID plate small 2.jpg (36.92 KiB) Viewed 978828 times
jboright
Postby Fly4rfun » Sun Oct 18, 2020 8:56 pm
recently purchased a O'Day DS1. no sails or lines, last registered in 2002, no title, looked pretty bad but cleaned up nicely. needs more still but a big improvement. found the ID plate today.
MFG O'Day hull No. 15295 Class 2675 so i think its a 1967 or early 68 as i saw a 67 with 2635. any light would be appreciated. also has been Named "Sail Aweigh"
Garry
"Sail Aweigh" 1966 DS1 #2675
Fly4rfun
Postby GreenLake » Sun Oct 18, 2020 11:01 pm
In those years they were being built at steady rates, so you could take a few numbers for which people suggest a year and plot them and then see where yours would fall (not all the years are correct, so you need to make a "scatter plot" and then estimate a line through it to get the best guess for when yours was built.
Postby Fly4rfun » Wed Nov 11, 2020 2:57 pm
GL i believe mine is a 1966 model. any update info appreciated.
Fly4rfun
Postby HvB » Fri Jul 08, 2022 10:15 pm
I just acquired a Daysailer II with a small plate on the inside of the transom engraved "HULL NO 24827 CLASS NO 4768". If I interpret the number list correctly, this boat is either late 1971 or early 1972. Do you agree with that?
Hans van Beek
HvB
Postby GreenLake » Sat Jul 09, 2022 7:19 pm
Looks that way from the surrounding sail numbers in the list in the first post. There's a bit of a "wiggle room" as sail numbers and hull numbers aren't perfectly in sequence in the earlier years, but basically that's the information we have.
Welcome to the forum! If you are new to sailing, new to sailing small boats, or simply rusty, check out: "Basic Concepts and Techniques". (If neither, check out the topic anyway and leave a critique in the neighboring thread linked from the first post).
Postby YachtDaysiler181 » Tue Apr 23, 2024 9:06 pm
Sail Number #181
Hull Number #2385
Bounty Queen
Missoula, MT
James Maxwell
Missoula, MT
5% Owner of DS1 #181
YachtDaysiler181
Postby jcbartel » Wed Apr 24, 2024 2:22 pm
1982 O'Day DS II #12069 Chris Bartel Cleveland, OH
Name WIT
Chris Bartel
jcbartel
Return to History
