I recently bought a DS II which has chips in the fiberglass both inside and outside the boat, nothing major. To repair these I plan to use polyester resin and gel coat. However there is a 1.5'' crack in the
top of the cuddy by the hole through which the mast passes. I'm not sure how best to repair this.
Would polyester resin be strong enough to bond the crack? Or would an epoxy like the West system
be better?
Rick Dennis (dennisrl-at-us.ibm.com)
