by GreenLake » Thu May 03, 2012 4:19 pm
We've had the wind actually whistling in the rigging during one of our beer can races here and we were sailing with jib up (and possibly a single reef in the main - I sometimes do when my crew isn't that experienced). That was with a total crew weight of about 380 as equipped. I think the sound effects meant the wind had definitely reached well into the 20s for the duration of that gust.
On the other hand, I was cruising with two friends in about 16kts on the same lake, and decided reefing the main and striking the jib was just the ticket. The ride felt very controlled, but anytime we hit any local wind shadows it got really slow...
If you strike the jib, raise the CB to maintain balance. (A partially raised CB will be further aft, just as the mythical "center of effort" moves aft when there's no sail in front). Even with that, don't expect good upwind performance. For that, you do need the jib and the CB down.
Handling higher winds is something where both temperament and practice come in. And it makes a bit of difference whether the wind tends to be more steady or really variable. The latter is more demanding. In the end, you'll need to practice to determine how far you are comfortable in higher winds, but I'd definitely encourage you to find out for yourself what works for you.
