by GreenLake » Thu Jul 30, 2015 7:27 pm
That would be Uffa Fox in '59.
The mast should probably not be dead vertical. That sounds like your mast is stepped too far back. A slight mast rake aft would be normal, and if you can't achieve this any other way, you may need to move the mast step forward a bit.
But as others have alluded to, you'd want to rule out any other issues, like trim. You aren't trimming your jib for example too loose and the main too tight? Or for your CB - you are sure that it comes down vertical when you think it is (and not have it angle forward a bit?). Finally, if your rudder isn't fully down, that can make it harder to steer and feels like weather helm.
At some points, your sails will be blown. Think of them as consumables (which they are, in the same way as brakes on a car -- at regular intervals much shorter than the life of the boat the sails will have reached the end of their lifetime measured not in calendar years, but hours of usage time strength of wind).
Investing in a new set of sails should come before trying to re-architect the sailplan. If you get a new set, and still can't trim them to balance the boat, then it's time to look at mast steps or similar changes.
