DigitalMechanic wrote:I think that I might not have the best fairlead placement on mine. The angle may be kind of sharp. I may have to either work on pulling it down closer to the cuddy top, or move that fairlead back a bit.
I just reread your post about my halyard blocks. Actually there were no blocks on my mast. just small horn cleats for the halyards. I had seen the blocks and horn cleats on the cuddy on the older models and thought that would be better than trying to reach the mast to cleat the halyards. so I rigged it up like the older models. I guess they started cost cutting measures at the time the made mine, 1983, . if you look close at the pic. you can see where the small cleat used to be right behind the cheek block.
I hope I don't have trouble with the jib sheet hanging on the cleats.
I noticed that yours has the jib track on it. The PO took them off my boat but I've been wandering if I should put them back on. I don't know if the adj.is worth the effort and money.
