GreenLake wrote:The DS will not sail upwind at all with only the jib. So, except for downwind-only runs that's not really an option. Only time I sail (very short distances) with jib only is either, returning downwind to the dock, I lower the main, so I can let the jib fly at the last moment to depower completely. Or, launching downwind from a beach, I may raise the jib, get up some speed, then turn up-wind to raise the main.
If you sail without the main, the problem is that your Center of Effort, the mythical point where the "effective" force of the sail acts on the boat, moves aft (you've just removed the forward component of it when you lowered the jib). The Center or Lateral Resistance, defined by the hull and the foils (rudder and CB) stays put. Suddenly you are out of balance!
A remedy is to raise the CB slightly, which moves it back a bit. That's the preferred combination if you can't reef.
If you have reef points, and if the winds are such that you know you want a reef from the moment you launch, you don't need any fancy set-ups. Here's my suggestion for a jury-rig.
Detach the outhaul from the clew and move it to the reef point. Fold down the sail, then use a few turns of a thin line to create a lashing that holds the reef-cringle close to the boom. In the front, make one lashing around the boom, another one around the mast, so that the forward reef point is "fixed" near the tack, but the boom can still swing. Then tighten the outhaul and the main sheet. The difference between this setup and permanent jiffy reef is that shaking out a reef isn't "jiffy" any more, but I see no reason why it wouldn't be an effective technique in a crunch,
domromer wrote:So use the outhual and a lashing to secure the reef point at the clew? Also at the tack I've got a hook. Should I still create a lashing at the boom and mast while putting the reef point through the hook?
domromer wrote:Found a pretty interesting video. Think I might rig up a system like this.
https://www.youtube.com/watch?v=0aQ9PMd8_9g
TIM WEBB wrote:No prob! I remember the Peep Hen ... do you guys still have Her?
Keep this in mind: when hove to, you can do pretty much whatever you want with the mainsail, since it's not really involved in the "equation". That's why I'm always hove to when raising or lowering sails if at all possible.
No worries on the adventures - they will all come to you in good time. Get your boat squared away the way you want it to be, then GO! ;-P
Time waits for no one, and the sooner you go, the sooner you will figure out the things on your boat that will make you want to go more and more ...
I haven't been to the Cedar Key event yet, but it's definitely on my "bucket list" (why is it called that? Just wondering ... ). I went to the Ft. Desoto dealio last Fall, but it was a washout. Had a great lunch with amazing friends tho!
Life getting in the way of sailing? Sheesh - tell me about it! But I find it's usually wx getting in the way when life grants you those rare opportunities to get yer water time ... <grin>
TIM WEBB wrote:Yeah, I haven't been to the Cedar Key event yet, but I've heard good things, and it's definitely on my "bucket list".
