original blocks? suggestions to replace?
Re: original blocks? suggestions to replace?
Postby SpeckledTrout » Thu Feb 07, 2019 10:10 pm
Folks, thanks for your responses. It occurs to me that I don't know if the original jib tracks have a backing plate inside the hull (and if so, how are those constructed). Seems logical there would have some kind of backing plates given the strain on the OEM blocks (no ratchet, etc). Does anyone know?
Regards,
Andrew
DSII #5996
SpeckledTrout
Postby GreenLake » Thu Feb 07, 2019 11:35 pm
Hadn't thought about that: the load on the jib track cars does change some based on whether you use ratchet blocks or not. Assuming the ratchet block is perfectly efficient and requires only minimal tension on the free end, the entire load from the jib sheet pulls forward.
For a regular, 90 degree turn around a block, there's the same force going forward as going sideways. The track will have to offset the tension in the part continuing to the CB trunk, so there's a net pull outward that matches the strength of the pull forward (which the track stop transmits along the track).
Now, ratchet blocks do require some tension on the free part to keep them engaged, and, more importantly, they act like free blocks whenever you pull in the jib, so you don't gain much in terms of required strength of the jib tracks.
In any case, yes, you do need backing, and you may need to cut holes for some inspection ports so you can get an idea what was provided for your boat and whether you can reuse that.
Inspection ports are covered in many DSII specific threads, just go back in time a bit.
Also, you can get neat little nets that make pockets inside the port, so you can stow things underneath the covers to keep them out of the water - (except that the bilge water can get at them). One guy I sailed with would stuff small plastic bottles in there as he was emptying it during long trips. At the end of the season, he would fish them out again.
Postby SpeckledTrout » Sun Mar 03, 2019 1:46 pm
Folks, much thanks for the recommendations. I bought the Ronstan C-cleat 'medium' size and it looks like it'll be a good fit. To be sure, I'll have to drill new holes to install these new cleats and would value feedback beforehand (cutting holes in boats is never an easy decision to me).
I do have a question for others who've made this upgrade:
option 1) did you install a backing plate when you upgraded the cleat? If so, did you have to remove the CB to access the area to affix the backing plate? Or, did you already have some kind of access port to reach that? Seems unlikely one would install an access port on the side of the CB trunk.
option 2) if you didn't install a backing plate, did you drill a hole and first insert a anchor/fastener .... and then used a screw to secure it?
option 3) if you didn't install a backing plate and you didn't use an anchor/fastener, did you simply screw the cleat to the top of the CB trunk?
Much thanks for any feedback.
2622
Regards,
Andrew
DSII #5996
SpeckledTrout
Postby Woreign » Sun Mar 03, 2019 4:17 pm
I just installed identical cleats on the angled surfaces of the centerboard trunk on my DS2. I faced them toward the jib rails so that they would hold the sheets at a perpendicular angle. To attach them, I made a paper template of the cleat so I could identify the location of the holes. I started two pilot holes, then used the cleat itself to center my drill bit. With the pilot hole, I knew the drill would remain centered and not drift. After the holes were drilled, I took a round stone Dremel bit and sanded small depressions around each hole. This prevented the gel coat from cracking when I screwed the stainless steel screw into the hole. I ran the screw into each hole first to set the threads in the fiberglass, then attached the cleat.
From what I read in this forum, there is at least 3/4" clearance between the trunk and the centerboard. So I chose screws that were long enough to extend that deep into the trunk. The screws definitely took a good bite into the fiberglass, so I'm not worried about them pulling out, especially when you consider that the forces they will encounter will be sheer and not perpendicular to the hole. If you're worried about using screws in the trunk, consider that the centerboard uphaul cleat is attached with screws with similar sheer forces pulling at it.
Woreign
Postby SpeckledTrout » Sun Mar 03, 2019 6:43 pm
Woreign, thanks for your note, I was thinking similarly. Using a appropriate SS screw that gets ample bite into the fiberglass ought to be sufficient. Plus, that's far simpler than other methods (and it doesn't lock me out of other options down the road).
Regards,
Andrew
DSII #5996
SpeckledTrout
Postby GreenLake » Mon Mar 04, 2019 12:36 am
Remember, you can always upgrade to ratchet blocks. That would tend to further limit the forces on the cleats.... and is nicer on the crew.
Postby SpeckledTrout » Mon Mar 04, 2019 10:10 pm
Greenlake, agree completely. I'm wondering if I could accomplish the same thing more easily.
I'd value hearing folks' opinions/feedback if I simply replaced the existing block with a new ratchet block, but I retained the existing jib track? As you can see in the photo, I have every reason to believe my jib track is OEM to the boat, circa 1970. There's nothing wrong with it and it appears that it could be retrofitted with a new ratchet.
Benefits to doing this...
1) avoid cutting access ports on each side
2) would avoid the costs of replacing the jib track
3) avoids the effort to make a clean installation.
Any cons?
2629
Regards,
Andrew
DSII #5996
SpeckledTrout
Postby GreenLake » Mon Mar 04, 2019 10:26 pm
If you can indeed replace the block on the existing cars, I see no reason why you would need to upgrade the tracks.
The key will be whether you can free the "U" that's mounted to the slide. Better not plan on inserting shackles or other extraneous parts - you'll want to recreate the approximate geometry you have now.
Postby Woreign » Mon Mar 04, 2019 11:37 pm
I haven't taken a photo yet, but I replaced the stock donut-hole and cleat with a swivel pulley. It attached easily to the piece that slides on the track with the stock pin.
I also like how the pulley lays flat against the side of the cockpit, making it less painful if a crew member happens to lean against it.
Woreign
Postby SpeckledTrout » Tue Mar 05, 2019 8:57 pm
Woreign, I'd value seeing the photo of how you configured that to work.
I'm planning to get the same ratchet block (Ronstan 55) that Greenlake recommended. I checked its dimensions and that block is ~0.5in longer than my current OEM block so I want to minimize what I use to attach it to the jib track fitting.
Regards,
Andrew
DSII #5996
SpeckledTrout
Postby Woreign » Tue Mar 05, 2019 9:37 pm
Here you go!
Woreign
Postby SpeckledTrout » Sun Mar 31, 2019 8:44 am
Folks, much thanks for your feedback/suggestions on this thread. I replaced the jib blocks w/ Ronstan Ratchet 55 blocks per Green Lake's suggestion and they fit great. I used Woriegn's suggestion to simply affix those to the existing OEM jib track and it worked well. And, I followed several suggestions to replace the OEM cam cleats with Ronstan 'Medium' ones. Now, it's time to go sailing.
Regards,
Andrew
DSII #5996
SpeckledTrout
Postby tomodda » Fri Apr 05, 2019 9:21 pm
Just to finish up this thread, Andrew generously donated his old cleats (original topic of this post) to me. Lucky me, much appreciated. The teeth are in fine shape, but as Andrew warned one cleat was barely moving. Being as I had a rainy afternoon off from work, I did a quick refurb. Disassemble, spritz of brake cleaner (nasty stuff but effective), 10 minutes of wire brush on the bench grinder, spot of silicone lube spray, put back together, and good as new! Snap, snap, snap... These babys will be holding my spin sheets before you know it. Just goes to show you, good gear - Schaefer in this case - can live forever. Just needs some TLC, but don't we all? Thank you, Andrew!
