[album]2658[/album]
Woreign wrote:I recently installed a tabernacle on my DS II. I cut the mast using hacksaw. I carefully marked where I was supposed to cut and took my time.
Even if you cut slightly off from square, the tabernacle fittings will square themselves when you fit them into mast.
GreenLake wrote:Shim below the mast for 1" to keep the top at the same level.
TJDSII6630 wrote:Best to fix these ashore. Found while careening. This is the one that did not fail. Hard to tell the mast is falling until it is about on top of you, but I managed to catch it and not get brained! Inches to spare!
Do not over torque, and I do not know what it should be. I used nylon insert nuts and made them just snug. The load of the shroud will be added to the load placed on the bolt by the nut. If it is a 10-24 grade 2 the proof load is 962 lbs each, clamp/working load is 723 lbs. Leaving 239 pounds to failure. 2 bolts gives 478 pounds but there is not any safety factor at that load. I think the shroud should be at say 250 pounds, so there is not much left for the wind load and from rocking at the dock. Being just snug, the shroud can apply 1446 pounds and still be in the working load range.
Users browsing this forum: No registered users and 117 guests
