The cable used to raise the main jumps the shiv. The shiv is plastic and newly replaced because it was so mangled from trying to force the cable by it anyway. Someone said they replaced the cable with line because they had the same problem. The thinking being that the cable has too much spring in it, line drapes and tends to stay in the shiv.
Suggestions?
Mary Lou (bright_sky-at-juno.com)
