Mast Tabernacle corrosion fix
Postby Spapa » Sat Jun 26, 2021 7:32 pm
Hi,
I have this going on at the mast tabernacle. Looks like corrosion is building up and causing separation of some sort. Any ideas about what’s going on and the right fix?
Spapa
Re: Mast Tabernacle corrosion fix
Postby jalmeida51 » Sat Jun 26, 2021 11:40 pm
I don't think corrosion is causing your problem, you do have some corrosion at the base of your mast. It appears that your tabernacle hinge is distorted. I have a 1981 Daysailer1 built by Rebel and after a sail in some strong winds I noticed my stays were rather loose. Then I had 3/32 shrouds and forestay. Next day I noticed the bottom hinge that bolts through the cuddy roof had a gap just like the gap on your mast. Two of the four 1/4 inch bolts were loose and pulling through the cuddy cabin roof. Also there was a smaller gap at the hinge at the mast base. I had a local machine shop make up a stainless steel plate to beef up my roof so the bolts can't pull through it. Upgraded the the shrouds and forestay to 1/8 inch with turnbuckles. Replaced the spreaders with heavy duty type. Replaced the tabernacle hinge. After all of that I haven't had any more problems.
You could remove the tabernacle hinge and lay it on a flat piece of metal and see if the hinge lays flat. If it is not flat you could try to pound it back into shape. Check the 4 bolts attaching the hinge to the cuddy and make sure your shrouds and forestay are tensioned properly. If you have 3/32 shrouds you should consider to replace them with 1/8 with turnbuckles.
Best of luck, John
jalmeida51
Postby Spapa » Sun Jun 27, 2021 2:39 pm
That makes sense. Thanks for the feedback!
Steve
Spapa
Postby jalmeida51 » Sun Jun 27, 2021 3:19 pm
Steve, One thing I forgot to mention was do you moor your boat? My owners manual states don't moor the boat. The boat out on a mooring could do damage to the standing rigging, bouncing around in choppy waters. I keep my boat docked at a very protected dock at a boat yard. I have had my boat on a mooring up in Maine for about a month with no damage. This was after I beefed up the standing rigging. If you are going to moor your boat talk to Rudy at D&R Marine.
jalmeida51
Postby GreenLake » Sun Jun 27, 2021 10:46 pm
Proper rig tension may also help with preventing damage.
Postby Spapa » Mon Jun 28, 2021 7:35 am
I trailer the sailboat. I looked at it a little more closely and it seems the corrosion is causing the separation as opposed to a bent tabernacle. I might just replace the tabernacle as I think it is "original." I recently purchased the heavier standing rigging, so hopefully that will add some strength to it all.
Spapa
