Day Sailer 1 Boom Vang ratio ?
Postby RockyStyer » Tue Jul 06, 2021 9:48 pm
New Day Sailer 1 owner: What is the recommended Boom Vang ratio 3:1 ?
My old Day Sailer 1 did not come with a boom vang from the Mast to the Boom.
D and R Marine has a Boom Vang Kit , with every thing IO would need to set my boat up, but the ratio is 3:1 - Is this the correct ratio?
RockyStyer
Re: Day Sailer 1 Boom Vang ratio ?
Postby GreenLake » Wed Jul 07, 2021 1:13 am
I'd recommend 12:1 at least. There are many discussions here, so a search would be useful. Here's just one of the more recent ones:
https://forum.daysailer.org/forum/viewtopic.php?p=39298#p39298
In brief, with a stronger vang you can use it upwind, where it will help you keep your main flat (depowered) when letting out the main.
That improves your gust response.
Briefly discussed here https://forum.daysailer.org/forum/viewtopic.php?p=37573#p37573
