David, I know for sure that there are discussions on aluminum rudder heads here. Several people have done them. I'm not sure how you can find them the quickest other than searching for "site:forum.daysailer.org aluminum rudder head" (without the quotes) in your favorite search engine.
I've not seen anyone make an aluminum rudder
blade before. The problem is that to get best performance you want a NACA profile at least 1" thick. Unless you can manufacture a hollow blade from aluminum, that gets heavier than you might like, and shaping wouldn't be fun.
Why not do a wooden blade, sealed in epoxy and with just a bit of glass for scratch protection (more where you tend to hit things...). And do an aluminum head for that.
A wooden blade has some buoyancy, but it's not too bad: you're not seriously loading the pintles and gudgeons in the opposite direction. Especially not with some weight in tiller, head and fittings. But that buoyancy means, you don't have the weight dragging down the stern; it's basically neutral.
A profiled rudder should perform somewhat better. When I did mine, it was hard to tell. Definitely not worse than before
. You may need another boat to carefully trial against in like conditions to note anything - the kind of thing that wins races but isn't observable in cruising.
I don't know about up and downhaul. Don't have either. There are some clever solutions out there and some you find discussed here. A while back, though.
