Hi all,
I am new to this site and just brought home my new O'Day DS1. After doing a lot of research and comparisons between the Lido 14 and the DS1. I decided on the DS1 for its size and stability. This boat is in pretty good condition for a 1966 the hull number 3877. The previous owner had done quite a bit of work on the boat but there still some issues that need attention. I plan to sail it this season after attending to a few of the immediate concerns and then restoring the boat this winter.
I am not sure if some of my concerns are valid or worth worrying about until this winter's restoration project. Any assistance I could get from anyone on the site would be greatfully apperciated.
First concern is there is no foam flotation in the seat tanks or in the bow. I plan to buy some pool noodles and stuff these areas full with them. There is a very small hairline crack down the length of both seat tanks where they transistion to the hull.
Also there are holes on either side of the centeroard trunk just foward of the centerboard. I poured some water down them but did now see it come out anywhere. There used to be a plug in the transom but it has been removed and filled. May have been the angle of the boat on the trailer also. Also in the bow area of the boat under the floor boards just foward of the trunk there is a spot that I can see light through the fiberglass. It is not a hole it just looks like it may be thin. There no cracks anywhere around this area and there does not appear to be any damage inside or outside the hull in this area. At first I thought this may have been from repeated beaching but no visible indications of such.
Any assist anyone could give me would be greatly apperciated
Thanks so much
Steve
