by Roger » Mon Oct 15, 2007 9:27 pm
I had the same issue. Short of eliminating the problem by making a guard or sheath or knocking off all of the sharp corners that catch the sheet, you can reduce the odds of the sheets catching by not letting go of the working sheet until you are passing head through wind, then allowing the jib to snap over to the other side, while as quickly as possible haul in the new working sheet to set the jib. In my experience the snappier the tack the less likely the sheet would catch that corner. I even tried duct taping the pin but there were just so many sources for entanglement. I suspect that a cloth shield over the front of the tabernacle might solve the problem.
I have a similar issue with the shrouds and the jibsheet on my current boat. I am solving that issue by placing a plastic golf club protector over the lower part of the shroud.
I notice other sailors on other boats have similar issues with cowl vents, and other gear mounted near or forward of the mast. When I ask them how they deal with it, they all have the same answer; a snappy tack. It is inevidable however that at some point a line will catch somewhere, and it becomes necessary to go forward and set it free.
