by Bob Damon » Wed Jul 30, 2008 9:13 pm
You are correct that the mast should be about 25'. Assuming you have a DSI the current mast is short and my question is if this was the original mast, or a replacement from another boat. Check where the cuddy top band should be, mark it, and take measurements from there for spreaders, shourds, etc and see if they fit. It might be a DS II mast which would be shorter than the DSI because of the higher inner hull where the mast step would have been in addition to the fact that the DS II masts where shorter than the class allowed maximums. Good Luck. Bob
