For the sake of space & convenience I'm considering removing the triangular interior forward "shelf" (inside up at the bow). In the process of patching some leaks I've discovered a few under this area. I already removed the vertical bulkhead that supports this small triangular shelf due to rot, and as 30% of the shelf itself is suffering some rot I'm thinking of just removing the whole thing.
This would make fixing leaks and upgrading the forward cleats and rigging easier as well. For that reason removal is a no brainer. I may leave a bit of the shelf around the edges for storage (putting supports underneath).
My question is this. Do the forward shelf and the bulkhead serve any critical structural purpose? Is there any reason why I can't just leave them out and make use of the additional space?
I'll put some air bags up there to replace the flotation that was there when I removed the bulkhead, but beyond that it looks like a great place for a load of gear.
Thanks for any advice you can offer.
Best,
Glenn
