boat cover
boat cover
Postby Tom Kearns » Fri May 29, 2009 6:20 pm
Looking for a used/new boat cover for a friend that just purchased a Day Sailor..it is a 17' O'Day Day Sailor...reply to tomkearns@kearnsgroup.com
Tom Kearns
Postby FF26 Truck » Fri May 29, 2009 9:31 pm
I purchased a cover from Intensity sails, www.intensity sails.com, and was very happy with the price, quality and service. They charge about $240. plus shipping which varies on your location, they ship from the manufacturer in California. The cover fits around the rub rail without the mast or boom crutch in place and has tie down straps to secure it. I keep the boat on a trailer with the mast on a support bar mounted on the trailer tongue and resting on the outboard bracket at the stern. To keep water from collecting in the cover at the stern, I fabricated a support bow from a length of fiberglass flat stock purchased at West Marine. The boat is now clean and dry and the deck is protected from constant UV exposure.
Good luck,
Kevin
FF26 Truck
Postby GreenLake » Fri May 29, 2009 10:48 pm
If looks don't matter, the heavy duty white tarp might be the cheapest solution.
They cost between $30-40 in that size and last 2-3 seasons. I figure that by the time I've gone through six of them, I'd be past the end of the life of any custom-built cover.
[thumb=681]
[click image to enlarge]
The mast rests on a mast crutch in the front (inserted into the hole in the cuddy) and another one (partly visible) that's fixed where the rudder goes.
(Note the opening for ventilation at the back).
Postby Phill » Fri May 29, 2009 11:20 pm
+ 1 for GreenLakes solution.
'cept the vent....i mean cat box entry :evil:
Phill
Postby ssawyer » Sun May 31, 2009 12:24 pm
I just purchased the mooring cover from SLO Canvas for $149. Ordered it online and received it in about 3 days. Looks to be well made, but is specifically designed for use with the mast up and boom supported, whether by crutch or topping lift. Since my boat will be on a mooring ball, this was a very good solution for me.
ssawyer
