Baysailer wrote:I recently lowered my coamings. Just requires cutting the tails up about an inch or so and sanding the rear coaming to fit. You will also have to fill and drill new screw holes.
The amount I lowered it was only about 3/4" in the front and 1 - 1 1/4" in the rear. It doesn't sound like much but it really helps in comfort. The coamings will still shed water and it makes the coamings less likely to break or split. It also keeps the look I like, you'd be hard pressed to see the difference. I'll drop some photos as soon as I get a new camera.
Fred
