Bailer repair
Hi, I have read lots on the bailer repair, tried to make a new rubber gasget..
That didn't work. Then I took out the whole unit and caulked every joint and seem with 3m 4000 marine sealant. Still leaked. So I covered the entire bailer with a layer of 4000, extended past the edges by an inch or so. Still leaks. Question: would it be better to buy whole new bailer, or remove bailer try to glass over the whole area. I don't mind the leak much, but worry that water will evevtually soak into hull. Suggestions? Thanks!
