Need help identifying Daysailer year
I just recently purchased an O'Day Daysailer 17 for $350 including trailer, 3 sets of sails, mast, keel, and rudder. The boat did need work when I first purchased it 3 weeks ago and I have been working vigorously between 3 jobs to try and restore it to some beauty.
The kid that I bought it from told me it was a 1998 O'Day Daysailer because that is when he purchased it. I had stumbled across and old closed thread on here about looking for a HIN # and a plate on the inside of the hull. My Daysailer doesn't seem to have either of those.
When I purchased the boat, the hull was white and the top deck was a god awful baby blue color that had faded away. The top deck had tiny pits in the fiberglass that I had sanded down and filled with fiberglass filler. I then used Rustoleum Marine Topside Paint with Anti-Slip Additive in white and did and additional coast of white semi gloss as an added layer. The hull I painted with Rustoleum Marine Topside Paint in Navy Blue Semi Gloss 3 coats. (1 coat with a foam roller, then 1 coat with a brush then the last coat with a roller again).
Everybody I talked to at Westmarine told me that as long as I wasn't keeping the boat in salt water all the time, then top side paint for the hull is fine.
So tomorrow I am going to stain my side stripping, finish off staining my 2 seats, stain the cover I made for the aft sink/cooler and start to paint the inside bottom.
I still need help identifying the model year if my Daysailer though. All I have found for a number on the Mainsail is "55" and "6/74". The "6/74" looks like it was written in Mil-Spec Type and the type set is about 1-2" tall and on one of the corners of the main sail
