DaySailer1 ??
Hi All
Big boat sailer who just bought a Daysailer to have a boat at the nearby lake.
I believe it's a 69, that's what the title says ,can't find a HIN
Registration says #5 but I believe that to be an assigned number by the DMV
This boat has diamond spreaders on the mast,motor well, lever for centerboard
and what appears to be some type of plastic cap on centerboard trunk, jib blocks on the
Inside of the coaming, sheets led to crisscrossing cam cleats on the CB trunk,
triangle traveler type thing for the end of boom main sheet.
I've sailed her a few times and had great fun, however 99% of time I single hand
so would like to make a few modifications
On another DS at my lake I've seen a mod in which a channel made out of wood is
bolted to the top of the CB trunk with the jib sheet cams cleats face in aft not sideways.
On this boat the trunk is solid fiberglass. So my question is what is under the
CB trunk cap? Is there enough room to get a set of bolts thru?
With the end of boom sheeting is it worth the effort to put in a real traveler and not just the ability
Let the triangle go to leeward in a stiff breeze? Any advantage to be able to pull the boom to windward
In light air?
I plan to add a vang which is not on the boat as well as a set of reef points and associated rigging.
Anybody put an extension on the CB lever to raise it from aft while beaching single handed?
Would a 35 pound thrust motor be enough to get away from the dock or beach
and push the boat a short distance if the wind goes mustang?
All that said I find sailing the DS to be great fun and a nice break from big boats
Tiller in one hand, main sheet in the other, wind in my face and the whole boat for a boat buck
Loving It
Thanx in advance
Neil
Cheers
In light air?
Loving It
Thanx in advance
Neil
Cheers
