Outboard Motor Questions
To be completely safe and fun while teaching my grands how to sail I need to add an outboard motor to my DS1. The original owner gave me the original motor mount so I plan on using it. However, I have the following questions since I have never done this before:
1. Can anyone provide best installation location information in the form of measurements? Perhaps from the top and center of the motor mount is best? Below is the my motor mount.
2. I have two motors available currently to purchase. Both are 4 Strokes. One a Honda 2.5hp and the other a Suzuki 2.5hp. They are 31lbs. and 29lbs. respectively and fuel tank is on the motor. Both are short shaft versions. Will the short shaft (15") be the best choice or should I be looking for long shaft versions? While I want them to work well I don't want them to be dragging when not in use and in their most upright position.
3. What is the best/safest way to mount this? Should I use some backing material for mounting it (that's my assumption, to distribute the load)?
4. What is the best way to get the mount "level"?
5. Anything else I should be considering?
NOTE: I know some will say go with a high end electric. I'm not ready to dish out that kind of cash as this is an experiment that could be short lived. Not everyone takes a liking to sailing as we all know. In both cases I can get these motors for under $500 and they have very few engine hours on them. They are lightweight, even compared to the high-end electrics and can be stored on their side without fuel or oil leaking.
Thank you for your help!
