Journey to sailing...
Hi all,
We are new to sailing and new to the DSI1 but are enjoying it thus far. Its been a bit of a journey to get to here. I bought the boat back in the spring after looking around on and off for a while to find something to learn to sail on. When I got this vessel she was in a bit rough shape and needed a good cleaning and repainting.
While painting and working on it I found that there was a crack in the centreboard and was causing a leak... out of the boat. It had rained and there was some water inside which I was going to worry about later but as I was painting the bottom I noticed a leak which led me to making some repairs...
With all this done I came to the realisation that didn't have a way to trailer the mast in a way that I wasn't worried it was going to fall off. So I made a stand to hold it on the back and then strapped it to that and the front of my trailer. (I'm adding pictures for the first time here so I hope this works) I'm curious of peoples thoughts or if you have better ideas.
Also a post painting and repair picture:
After this issue was solved we were out sailing Lake Erie and I saw that one of my stays came detached from the spacer and after coming back for the day I found it was only attached via electrical tape. I wrongly assumed it was just wrapped with tape to prevent cuts fraying etc etc...
Regardless, I made this fix and was out again yesterday evening and it all seems to work well.
In the end we got some good sailing and I'm sure there will be more to fix and figure out as we go...
Some screenshots from our trip on Lake Erie:
