Questions from a new DS II owner
Re: Questions from a new DS II owner
Postby TIM WEBB » Fri Jan 25, 2013 3:53 pm
If you don't have/can't get the swaged ball part, this little gizwizzy also works in the keyhole slot of the vang bracket:
http://www.intensitysails.com/hoalcuvakeyf.html
Postby klb67 » Sat Jan 26, 2013 9:17 am
Well, Tim, I didn't know such a gizwizzy existed, and $3 is a whole lot better than the $25 ish I'd be spending for the swaged ball/wire set up. Thank you.
Now I just need to get a shopping list for more stuff from Intensity to make better use of the shipping. Halyard cleat and new pintle pin for the sunfish...what else...
1976 DSII - #8039
klb67
Postby GreenLake » Sat Jan 26, 2013 10:13 am
Watch out, you're going to be over that $25 limit before you know it :)
Postby TIM WEBB » Sat Jan 26, 2013 11:08 am
Well, if you want to really go big ($$$), two of these have made a huge difference on The Red Witch:
http://www.intensitysails.com/ha1bigbublwi.html
Postby GreenLake » Sat Jan 26, 2013 2:03 pm
The price for these "Harken #140 Big Bullet Block with Cam Cleat" is really competitive. Most other places sell them for above what Intensity Sails gives as their pre-discount list price.
Postby klb67 » Sat Mar 30, 2013 8:25 am
Tim - my vang plate must be slightly different, as I picked up the laser vang key, and the shaft is just a bit too wide to fit the slot, and the head is just a bit too big to fit in the hole. I may try to file on it a bit to see if I can get it to fit, but I'm concered about weakening it.
I may have to check my local sailing shop to see what options they might have, and my specialty hardware store. Or bite the bullet and get a proper swaged ball set up.
1976 DSII - #8039
klb67
Postby TIM WEBB » Sat Mar 30, 2013 11:03 pm
Hmmm ... weird? The one I got fit just fine ... ?
Either I have a different vang plate than you do, or there's a lot of tolerance in the dimensions of that key?
Either way, I'd get it to fit either by filing or whatever. The plate, not the key. The former is stronger than the latter, and after all, it's not a big deal if the vang fails ... ?
Users browsing this forum: Google [Bot] and 17 guests
