Rotten Floors
Rotten Floors
Postby Guest » Wed May 05, 1999 12:00 am
This message is to inquire about my floor in my boat. She was built in the early 60's(guess) and I pulled her out of a mudpuddle last year and have began restoring her. Miracle has had quite some interesting problems. They put rebar in for support of her cabin top and the fiberglass that it was encased was destroyed when it rusted! Yesterday I found that her floor in the section forward of the centerboard was delaminating. I started a careful demo and found that there was seaweed growing underneath a piece of plywood. Under the plywood there was some foam that was so soaked with water that it weighed about 55 lbs. I removed all of it and found a valve in the forward floatation copartment and cut into that also. It seemed very moist in there too. My question is in regards to hull strength. I thought about laminating bilge stingers or ribs and leaving the foam out so that air circulation will keep that glass dry. Has anyone had any experience with this? Ideas would be greatly appreciated as I sit here and hmm and haw about what to do next.
Eric J. Nelson (daysailor17-at-hotmail.com)
Postby Guest » Tue Jun 08, 1999 12:00 am
I am writing to inquire once again if someone can help me by measuring the distance from the forward end of the centerboard trunk to the mast step. I have a DS 1 and am in need of assistance.
Eric J Nelson (daysailor17-at-hotmail.com)
Postby Bob Hunkins » Wed Jun 09, 1999 12:00 am
Do you happen to know the hull number? That information may help find a boat that is as close to yours as possible for measurements. I've seen it on a small plaque on the forward flotation tank inside the cuddy, as well as on a plate on the wooden combing that runs across the aft end of the cockpit. Sounds like your boat is an old O'day, (1960's you said) so the number isn't stamped into the gelcoat on the exterior of the transom.
Bob Hunkins
Site Admin
