Greetings to the collective,
The ice finally went out yesterday here in northern Ontario and with temperatures close to 75, I tackled the first step in repairing an over-canvassed misadventure of last year. (I blew a come about and went prow first into a very rocky shore....several times.) The damage was relatively minor. A silver dollar sized piece of gelcote missing (down to fibre) right on the prow at the waterline and a few radiating cracks from the impact site. I dremmeled the edges, removed loose stuff and feathered out the star crazing. After a good wipe down with acetone, I placed a fist coat of a product called "FLEX SET" which is supposed to be non-sag epoxy that resists vibration, bending and shock.
Here is my question: This is my first time working with epoxy. Should I aggressively sand to basic contour so there is a good "tooth" on the repair surface for a second coat, or should I apply a second coat directly over the first with no sanding? This material comes with tons of instructions (including a prominent warning that "this product contains a chemical known to the State of California to cause cancer"), however no directions about the second coat.
As always, all help is appreciated.
Regards,
Marv
