Missing one side of the tack mount on DSII gooseneck
Greetings all,
While scrutinizing my boom gooseneck today to answer the 90 degree flex question (a different post), I noticed one of the cast pieces that support the tack pin was broken off. I have only put my used sail on one to test fit it, and I can't honestly say if it was there a month ago or not, but it's not there now.
Starting from the premise that you definitely want one on each side, and thinking that this is something that can't likely be garage repaired, I probably need to buy a new gooseneck assembly. (rats! yet another budget buster...) I went to Dwyer Mast and of course they have 25 different sized booms to select from before you can pick your hardware. D&R offers only one, so I assume that is the correct one (1.75 x 2.75) can anyone confirm that? (didn't think to measure at the boat).
D&R also sells just the boom casting (which is the part I need) and therefore I assume it's "possible" to de-construct the existing one and save the spring & gooseneck part for reuse?
Has anyone ever disassembled the gooseneck end of a boom?
Just looking for some supporting commentary (piece of cake, you could do it in your sleep, no problem! sorts of things) before I attack it. I guess the best bet is to take it apart first, and then if successful, just order the casting. If it falls apart in 100 pcs. then order the whole head (I've got the whole winter... it's not like I'm in a hurry). And now, looking at the pictures, of course it's a rivet. Any suggestions on best way to drill out a rivet? I'm sure I've done it before, but I think they've always been pop-rivet's... and I can't think of I time I've done it while trying to retain the facing that the rivet is through. Is it better to try to grind off the head, or drill it out? Any opinion is better than the one I have right now. I suppose the worst that happens is I end up shortening the boom by 1/2" if I have to cut the end off.
Again, I'd be happy to hear from anyone with any experiences in this segment of the DSII reconstruction process.
