Repair - restoration - painting deck and cockpit
Happy pre-new years to all,
As I'm working my way through my boat repairs and restorations this winter, I am seeing lots of small & medium gel-coat chips, smudges that just won't wash out (or even bleach out) and those kinds of things, and starting to think maybe I should paint the upper surfaces this spring.
I know everything looks much worse under incandescent light in the pole barn and once it's back outside in the sun maybe it won't be so bad, but for now I'm doing some planning prep, just in case.
I've looked through the forum and other than a conversation about the pros and cons of various paint products, there's not been much discussion on topside painting. As I've been working around the foredeck I've become more focused on the very large repair performed by some previous owner or agent thereof.
[thumb=1148] [thumb=1149]
It's easy to see in this picture that there was a substantial foredeck repair done at some point and whatever the patching material was (be it Marine-Tex or Gel-coat or whatever) it left a smooth surface running across the anti-slip texturing of the foredeck, and is very noticeable.
So... is anyone aware of a way to even "sort of" restore a non-skid look to this smooth surface? Maybe a not legitimate, but conceivable answer could be sanding the smooth surface down, re-coating with a layer of some hardening material (bondo, body putty, fiberglass, epoxy??) and then applying a reverse textured mask over the top to reproduce the texture into the coating? Or maybe there is there a imprint roller that can be used to create textured paint jobs? Or is all of this simply a fools errand, this kind of restoration is not possible short of cutting off the deck and entirely replacing with new base material. Be that the case I'll probably just paint over the top and live with it.
I suppose another alternative would be to smooth coat all of the textured surface of the foredeck so it's the same (flat), and then add some non-slip materials (grit or whatever it is) again to the final coat.
Has anyone ever taken on a restoration such as this with any success?
Maybe it will look better outside and I'll talk myself out of the obvious excessive labor this will take.
Thanks - Scott
Thanks - Scott
