cooler lid repair question
I have a bunch of cooler lid questions.
My cooler lid was held on by a bungee type cord - is that original?
I removed the lid - the underside has what I think was a wood panel in the middle, glassed in. Was that original or added? The outer layer of glass was cracked badly and the "wood' was a soggy mess. I cut and removed the outer glass layer and the wood inside - I'm down to the fiberglass lid.
Should I replace the soggy wood with anything? Glassed-in plywood? Some type of foam? What purpose does it serve?
The underside of the lid was painted green. Was that original?
Thanks.
Thanks.
