Winter Repairs Continue Into Spring...
...and on into the summer at the rate things are going. Boat repair time seems to be in short supply.
When I last posted, I had dropped the centerboard of my DS I and was sanding off the nasty, noxious anti-fouling paint applied by a PO. Then I used epoxy putty to fill the many chips and cracks in the board. A large piece of resin had split away to expose a steel reinforcing rod in the center of the board. I used a Dremel to grind off as much rust as possible, and then covered the "rebar" with epoxy putty.
A heavy snowstorm in early March left me with two days off work, but without electricity. Fortunately the shop has lots of natural light and some non-power tool work could be accomplished. I made a cardboard pattern for an insert to fit inside the square hole for the CB handle. Hopefully this will keep the handle shaft from abrading the inside of the square hole. Later I will make the insert from .025" copper.
I used a chalk line to establish centerlines on the leading and trailing edges of the board.
Then I leveled the board on the workbench and spiled a cross-section onto a sheet of poster board.
I laid out an improved cross-section on the poster board and used a thin wood batten to draw a fair curve. The new cross-section is not exactly a NACA foil, but it's close and will be a vast improvement over the stock centerboard.
I used the poster board pattern to make a template for building up the CB to its new improved cross-section. Think of the screed board a builder uses to level your concrete garage floor. (This works better on a flat concrete slab than it does trying to mold epoxy into a convex surface.)
Then I applied epoxy thickened with wood flour in an attempt to reconfigure the CB. I extended the trailing edge of the board to approximate a NACA foil shape, although as you can see from the photo there is still work to be done.
Here's where things went wrong! A combination of high ambient temperature (80* F), mixing too large a batch of epoxy, and perhaps adding too much thickener resulted in a mess when I epoxied the CB. The epoxy set up with a zillion tiny air bubbles trapped inside. They resembled the bubbles that form in pancake batter just before you flip the pancake.
So, guys, I'm seeking your advice on how to proceed. My thought at this point is to sand the whole mess, which I need to do anyhow, and open up as many bubbles as possible. Then I would apply unthickened epoxy to fill the exposed bubbles and continue building up and fairing the surface of the CB. Of course I will have to flip the board over and work on the opposite side to achieve a symmetrical cross-section. I'm planning to wrap the whole CB in a couple layers of glass cloth, so the risk of water intrusion or lost strength from the remaining unfilled air bubbles should be minimal.
What do you think of this plan? BTW, I don't recommend trying this repair method at home. Rather than trying to repair the old centerboard, building a whole new one would have saved time and money.
