Mounting for swivel cleat
Postby rnlivingston » Tue Oct 01, 2013 6:14 pm
Not sure where I saw it, but I remember a wooden frame attached to the centerboard trunk to mount the main sheet swivel cleat. Is the wooden frame screwed to the trunk or through bolted? I would like to do the same thing on the 1966 Daysailer I just restored.
Roger Livingston
DS 6872
Mariner 4096
rnlivingston
Re: Mounting for swivel cleat
Postby K.C. Walker » Tue Oct 01, 2013 9:51 pm
When I set mine up I used screws. No signs of problems four seasons in. Image
Postby GreenLake » Tue Oct 01, 2013 10:22 pm
The primary load is on shear, so, yes I'm not surprised. While you should be able to throughbolt as well, in that location, you have the benefit of not having hex heads and nuts stick out that way. One good-looking piece.
