Rebirth of 2444
Last year I was given a 1966 Daysailer 1. It had sat on a trailer for 20 plus years and the hull and trailer were in sad shape. After countless hours and about $1500.00, my free boat was back in the water. Since any boat I own is never finished, I am once again working on this wonderful old Daysailer. Last year I replaced the stiffeners, but did not paint the interior. So I removed the thwarts, sanded and sanded and sanded, and painted the interior with Interlux Bilgecoat. We'll see how it holds up. Last year, I had trouble putting the rudder on and off. The metal trim at the top edge was getting in the way, so I moved the gudgeons out about a quarter inch using spacers made from a nylon cutting board. I'm converting the main sheet to mid boom, so I installed a new Harkin swivel. Although the original jib cleats on the centerboard trunk worked well enough, I hack sawed them off and installed up to date cam cleats. When I tried to reinstall the thwarts, I discovered the hull had pulled apart about a 1/4 inch. I later careened the boat over on its' side which pushed the sides together the 1/4 inch I needed to attach the thwarts. The old mast had diamond wires on it which I removed to see if I can get a little mast bend.
After pulling the boat over on its' side, Sally and I removed most of the old paint on the bottom with scrapers and sander. I have to fill in a slight indentation in the bottom where it sat on the trailer. I will also fill any dings and scratches, prime it and paint it using Interlux Brightside. I drysail my boats, so do not need antifouling.
I'll keep you posted.
