spreader vertical movement
Hey all:
Spreader question -
Should they be loosely attached to the shrouds to allow for vertical movement, or, once adjusted, should they be rigging-taped in position? If the latter is the case, should they be adjusted so each spreader bisects the shroud-to-mast space into two equal angles?
Carlos
Spreader question -
Carlos
