New DS II owner with some questions
Hello everyone. I am a new DS II owner, and would consider myself new to sailing. When I was in high school we had a AMF Alcort Puffer that I sailed quite a bit, but that was 30+ years ago. The sailing itch was re-kindled on a vacation earlier this year and I decided to buy a sailboat. I found a Daysailer II and bought it. I have only had it out once so far. It went very well although I wish we had a bit more wind, but after that outing I am thinking about making some changes.
1. I already bought and installed a tabernacle to make mast setup easier. Prior to installing the tabernacle I noted that the mast shrouds/forestay were a bit loose. That hasn't changed since the overall mast length is the same after the tabernacle install. What is the procedure for adjusting the tension on the shrouds/stay?
2. I plan to add a topping lift for the boom and would like to see others setups for this. I am thinking about one that is fixed at the top of the mast with a small block and cleat on the boom for adjustment. I have even thought about just fixing a line at the top of the mast with it attached to the boom with a taut line hitch.
3. Rigging - All of my rigging lines are looking a bit suspect, so I would like to replace them. Some of the lines seem to be too big for their use. Is there a list of what size and length lines are appropriate for the halyards, sheets, etc. Also, a recommendation for a brand of lines to use.
4. I'm thinking about replacing the standard halyard cleats with cam cleats. Would there be any reason not to do this?
5. Rudder uphaul and downhaul. My rudder doesn't have either and I don't see any evidence that it ever did. Does anyone have recommendations for adding these?
Thank you all in advance
