Topping lift & pole fitt dimensions
Postby prochase » Fri Nov 27, 2020 1:08 pm
Can someone provide the dimension from deck to the spin pole fitting on mast and topping lift hoist bock?
Thank you,
Eric
prochase
Re: Topping lift & pole fitt dimensions
Postby GreenLake » Fri Nov 27, 2020 8:50 pm
The class rules allow two positions - found in the bylaws chapter 3 on the main DSA site: https://daysailer.org
I'll look for the dimensions for the hoist (I was sure we had this here on the forum in a recent discussion, but I can take a measurement).
Postby GreenLake » Sat Nov 28, 2020 6:26 pm
Still on my list.
Postby prochase » Sat Nov 28, 2020 7:29 pm
Look forward to getting the dim.
Thank you,
Eric
prochase
Postby GreenLake » Sun Nov 29, 2020 10:49 pm
Yeah, like, I've been walking past the boat dozens of times and never remembered, and now that I'm sitting away from it at the computer .... will get to it.
Postby GreenLake » Tue Dec 01, 2020 12:09 am
OK. Here's the info. The topping lift fitting is at the level of the spreader brackets, pretty close to 116" from the bottom of a keel-stepped DS1 mast. (Couldn't get a super precise measurement with the covers on).
The ring on my boat is 58" from the bottom of the mast. Class rules allow a second position, but you'd need to look that one up. If you never race, and don't have a ring installed, an alternative would be to mount one on a short track; that way you could adjust so the pole is level.
But, it would make the boat not class legal, just in case you do intend to race in class-sanctioned events or sell to someone who does.
