Reef Points in Main Sail
Postby texaspsdx » Mon May 09, 2005 5:22 pm
How many have reef points in your main? We were out last Saturday and it was windy and got to thinking it would be great to have a slab reef to shorten the main. How far up on the main are your reef points? Thanks!
Ron
texaspsdx
reef points
Postby Roger » Mon May 09, 2005 6:40 pm
My first (and only) set of reef points is just under the first batten. If I recall correctly that was 39" on the luff and 43" on the leech of the main. I sent it to my sailmaker and he charged about $90 for the two crinkles and 3 intermediate grommets.
I have not had opportunity to use it yet, so cannot comment further. I would assume the next set up, would be the same percentage reduction in sail area, and closest to the next batten?
I set mine up with a single line jiffy reef, but if I was doing it again, I would set it up as a two line jiffy reef, to reduce the amount of loose line when reefed.
Return to Sails
