Is D&R the only supplier that I can get battens from? The sails I have only came with 2 battens so I need to buy 2 more, 1 of each size.
Thanks...
Posted: Tue Sep 15, 2009 10:15 am
by Bob Damon
You can also get them from West Marine, Annapolis Performance Sailing (www.apsltd.com) or from the sailmaker such as North, Intensity Sails, etc. You simply need the length and width and specify if you want the batten tapered. If performance is not an issue, I have used wood molding from Lowe's that works just as well.
