traveler??
traveler??
Postby tommarc » Sat Aug 09, 2008 11:39 am
My DSII has a main sheet that runs to a swivel block mounted on top of the CB trunk. There is no traveler set up. Is this standard with the DSII and is there any reason not to install a traveler system? It seems like a good idea to have one.
tommarc
Postby shawn » Sat Aug 09, 2008 11:14 pm
It depends on what you are looking for. The original set up works fine for just sailing around but the traveler gives you alot more control if you are of a more competitive nature. Whenever there is another sailboat on the water I immediately go into race mode (drives my wife crazy) so I changed over to a traveler on the stern. Phill has some great photos in his gallery. His is a DS I so yours wouldn't look exacatly the same. I put an eyestrap on either side of the transom and then ran the control down the transom to the a block near the bottom and across to a cam cleat at my feet. Sometimes though, they can just complicate things to those who like the KISS philosophy.
Shawn
DSII 10542
shawn
Postby PG » Tue Sep 09, 2008 12:08 am
I am in a similar situation in terms of rigging (mid boom) and debating whether to get a traveller. In high or gusty winds a traveller would take some of the heel out of the boat before having to reef the main, but do I really want to trip over the track every time I move fore and aft? Not really.
PG
travelers
Postby adam aunins » Wed Sep 10, 2008 11:03 pm
This web site is a good one for different traveler set ups you can run on the DS. http://www.arlingtonyachtclub.org/Fleet ... velers.htm
adam aunins
Postby jbsailer » Tue Oct 14, 2008 8:36 am
switching to a traveler will give you much more control especially if you do not have a boom vang. Sailing down wind you can keep the boom lower and sailing upwind the end of the boom can be held closer to the center line of the hull and the sail flatter.
jbsailer
